Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Lines on screen after replacing the screen
Hi there, I replaced the screen on my iPhone 4 (again) and i started it up and it was perfectly fine, so then I factory reset the phone, I finished setting it back up, after which when I got to the Home Screen, a bunch of lines started showing up on the screen, i then went to settings to see if I could fix it, and the lines went away, but as soon as I went back to the Home Screen the lines came back, it gets really bad in the camera and photos apps. All help would be appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Turns out I had gotten a faulty display again. I replaced it with a known good one that I tested myself and sure enough the phone works!
Punteggio 0
Aggiungi la tua risposta
TechVid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 111
