Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
trying to replace case on nintendo switch joy cons
so long story short im trying to replace the casing on a set of joy cons and the casing that i bought... doesn't have a instruction manual in the box ._.
the rear casing won't come off after unscrewing all the screws also
help???
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
https://www.youtube.com/watch?v=ymBbKWzL...
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
Hello. I believe that the ifixit guide for joy cons might help. They explain how to take them apart and disassemble it.
Just use the part where they talk about joycons
Smontaggio Nintendo Switch
Punteggio 1
Did you remove the rails before you took out the screws? The back plastic should come off relatively easily.
Be sure to open it like a book with the part that slides into the switch as the books spine.
Check out this guide for how to get into the case.
Punteggio 1
Aggiungi la tua risposta
timtom77 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 150
