windows button is not working
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
got the same issue. wasted my two days try to find out what was wrong, well maybe a bit late but here is what happened
you may enabled the STUPID Win key disable function by accidentally pressed the Fn and Win, which is conveniently placed NEXT TO EACH OTHER, and just make things worse, there is no indicator light like the caplock, so good luck to find that out. Thanks Asus
Wow! Amazing!!
You helped me the most
I spent a few hours trying to restart the computer, update BIOS and only your answer helped me
Thank you!!!!!!!!!!!!!!!!!!!!!!!
I signed up to the site just to thank you
Hey Thank you from me too, I had to ask one colleague of mine who was younger than me, he did not tell me how to do it instead was showing off a little.
Now I can fix it myself.
Well you can try the following solution
For more you can read this
Hi,
Here's a link regarding what to check if the Windows key is not working.
Hey Team ! If window button is not working in ASUS Please turn off gaming mode in setting's
Thanks.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 278
