Salta al contenuto principale
Il terzo aggiornamento del controller wireless dell'Xbox è stato rilasciato a novembre del 2020, insieme all'Xbox Serie X ed S. Il controller è anche compatibile con i precedenti modelli di console Xbox One e i PC.
Problem with LT and RT always pressed
The left and right trigger always keep pressed, this problem began when i replace(
solder and desolder) both stick, first right stick and the controller works normally but when i replace the left stick the problem began.
This video show better the problem(this is the official xbox app): https://1drv.ms/v/s!AhpypwlrW5KohIBgdkgz... as you see the lt and rt button keeps pressed but the others works normally and this is another video with other app(the problem is more visible with this): https://1drv.ms/v/s!AhpypwlrW5KohIBhcMTA...
Thanks in advance.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
4 Risposte
Risposta più utile
I just came across this problem on LT and fixed the problem by replacing the U11 component (303 hall effect sensor for the trigger) with an old xbox one controller 304 hall effect sensor.
Punteggio 4
2 Commenti:
Just wanted to say thank you for this! I didn’t need to replace it but reflowing this chip fixed the issue for me! I wouldn’t have even known to touch this component had it not been for your comment.
da
@stuffmonster I'm glad I was able to help someone with this solution. One less controller in the bin. 😎
Thank you!
da
Check U9 controller on a board. On output should be 1.4V. I have a solution but it's not very nice. Connect output trace with 3.3V. It worked for me but I don't guarantee that it will work for a long time. You could also replace this IC. Problem is that it's a very small piece and it is easy to burn using hotait. Sometimes this IC doesn't have any specifications on it (especially in 1708 and older) so proper resoldering it can be quite tough
Punteggio 0
2 Commenti:
do you mean inject voltage on the trace to fix it?
da
Yes. It helped. I don't remember where specifically I connected it, it was a long time ago. Maybe before a voltage divisor if there was. I remember that those sensors have common power so if there is no power, they both don't work.
da
WERE you able to fix it?
Punteggio 0
If anyone encounter problem with LT and RT trigger always pressed, replace U9 controller, for me it worked, and I even used U9 chip from Xbox One controller and soldered into Xbox Series Controller and yes it worked if someone was wondering.
Punteggio 0
Aggiungi la tua risposta
rafaeljevi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 29
Ultimi 30 giorni: 156
Tutti i Tempi: 5,328
