Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
Why my phone will not switch automatically to cellular data?
I have the a1662 5se older model I bought 7 years ago. When i leave home it will not automatically switch to cellular data. Phone service says i have to do it manually to do sending texts or getting on the internet. I think it is more of a problem lately. Or is apple making my life difficult so i will buy a new phone. It also will not let me change the pin on my screen time part of the phone. So I can’t rest the network settings. Any ideas ? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Why do you have to switch? Isn’t it always on?
Punteggio 0
7 Commenti:
To get the cellular data to work i have to turn it off manually. It is Not switching on it’s own. So since i will not always remember to turn if offit will cause me to us up my data. So I figure apple is causing this on purpose.i have called themand they offer no explanation. As usual. If that is the case…i will not buy another iphone. But learning a new system is going to be difficult and prices are higher than they should be. So i am reluctant to anything till i find out more about this.
da
Your issue sounds like a software problem. Try resetting network settings via settings>general>reset>reset network settings. If that doesn't work, try restoring the device with iTunes or installing the latest update.
On a side note, you may want to upgrade devices as that phone is pretty much obsolete.
da
Yes, obsolete but it works for the little in need it. Also , I can’t reset the network since the screen time app is not accepting the code or allowing it to be set. I believe this phone has memory issues. Once it had to download the os since it wouldn’t recognize the phones code to open it. It’s just had to pay the money for something that doesn’t wash dishes or transport me to another universe.
da
It also has the most current update.
da
@Perry Green Why did you have to turn it off? When the phone is properly connected to wifi, cellular data will not be used.
It is too complex to troubleshoot jailbroken phone software issue, just revert it to almost clean stage.
da
Mostra altri 2 commenti
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Perry Green sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 154
