Salta al contenuto principale
Repair guides and troubleshooting information for hair dryers.
Why the air from my hairdryer is smelling very bad
The air is smelling very bad
Questa è una buona domanda?
Punteggio 0
5 Commenti
Hi,
What is the make and model number of the hair dryer?
Does it have a "burning" smell?
da
Check the back of the hairdryer. Sometimes there’s like a mesh that gets clogged up restricting the flow of air through it, if it doesn’t get enough air flow it will start to overheat.
da
Does you hairdryer have a screen for filtering out debris going into the unit? Did you check for hair getting past it, entering the heating element and cooking hair? Cooked/burned hair usually results from the unit ingesting hair and creating the terrible smell.
da
@notbroken you’ve just wrote what I said 😂
da
@strongbow, blocking or restricting airflow tends to allow the heating element to create hotter air temps without burning but any debris like hair getting into a hair drier will burn and melt creating the bad odors.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try cleaning the filter maybe?
Punteggio 2
Aggiungi la tua risposta
Rukhsana Begum sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 797
