Salta al contenuto principale
Lanciato sul mercato il il 24 settembre, il top di gamma Apple del 2021 ha uno schermo OLED ProMotion da 6,1", un nuovo sistema di fotocamera posteriore tripla e il 5G. È il successore dell'iPhone 12 Pro.
Broken LiDAR Scanner iPhone 13, rear system change
Hi, I replaced a damage iPhone with a pulled rear system form another iPhone, but have not transferred the former LiDAR Scanner. As there is a manual for this on here, I used the LiDAR sensor from another iPhone, but it seems to be paired to the iPhone as well. Has anyone ever exchanged a LiDAR Scanner successfully, so one that was not installed in the original device? The measure app (to test the LiDAR) just freezes….
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
The lidar in the pulled chassis probably isn’t compatible with the motherboard. Normally everything must be swapped over between chassis’s.
Punteggio 1
It might be possible you did everything correct. The housing might have the wrong LiDaR filter installed. A lot of housing suppliers will use something that looks right from the outside but doesn't function like the original filter. My guess is that it's not even a filter at all, just some paint. If you still (it's been 3 years) have the original housing, you might be able to transfer what's left of the original filter to the new housing (after you scratched off the knock-off paint inside the back glass)
Immagine
https://www.reddit.com/r/mobilerepair/co...
Punteggio 0
Aggiungi la tua risposta
MacMarcus sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 32
Tutti i Tempi: 1,271
