Salta al contenuto principale
Originally internally coded as LFA, the 2015 Sonata was unveiled in Korea late March 2014, and was unveiled in America at the 2014 New York International Auto Show.
How I charge f to c
How I change Fahrenheit to Celsius
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @baderalbadry
More information is required to help you.
Which temperature indicator do you wish to change in the car?
To convert F° to C° you can always use the formula (F° - 32) x 5/9 = C°
da
Hi jayff
Yes in my car sonata 1014
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @baderalbadry
Here's how to change the passenger compartment temperature display between Fahrenheit and Celsius, if this is what you meant.
To switch the temperature mode between Centigrade to Fahrenheit:
While pressing the MODE button, press the DUAL button for 3 seconds or more.
The display will change from Centigrade to Fahrenheit, or from Fahrenheit to Centigrade
Punteggio 1
1 Commento:
Do you know if this method also works for Santa Fe 2013/2018?
da
Preparati per le riparazioni future
Hi @erolmacc
On the heater/air con controls press and hold the Off button and then whilst still holding the Off button press the Auto button for >3 seconds and then release. This will change the display from Fahrenheit to Celsius and vise versa.
This is for a Sante Fe 2015
Punteggio 0
Aggiungi la tua risposta
Bader sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 39
Tutti i Tempi: 5,665
