Salta al contenuto principale
The HP Deskjet 2600 is a compact all-in-one inkjet printer series released by Hewlett-Packard in April 2017.
Refuses to print please help
It refuses to print. I tried everything I can think of please help
Questa è una buona domanda?
Punteggio 0
2 Commenti
What have you tried? "I tried everything I can think of. . ." does not help us help you. We need a list of what you have tried and how as in what did you actually do.
For example did you run "HP Print and Scan Doctor for Windows"?
And is HP Deskjet 2600 the correct model number? HP lists models 2600/2675/2676/2677/2678. Which is yours?
da
check everything I can think of nothing works, paper comes through as if printing but blank
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi
Have you tried the following
Connecting it to WiFi
Making sure ALL colours have ink left as if one runs out it won’t print
Make sure the paper door is closed properly
Try connecting though a usb cable
Make sure it doesn’t need a firmware update
If none of the above works let me know and we can further investigate
Punteggio 2
4 Commenti:
It doesn’t print just printing blank sheets
da
@valeriewhit3317
What is the result if you print a diagnostic page?
See p.88 of the user manual
da
No imprime solo imprimiendo hojas en blanco.
da
@jayeff imprime en blaco. los cartuchos son nuevos
da
Aggiungi la tua risposta
grossjenny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 780
