Salta al contenuto principale
Informazioni sulla riparazione per la Creality Ender 3 Pro, una versione aggiornata della stampante 3D Ender 3, prodotta da Creality. Rilasciata a settembre 2018. Numero di modello: Ender 3 Pro.
3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
Questa è una buona domanda?
Punteggio 4
10 Commenti:
was the printer bumped at all?
da
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
da
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
da
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
da
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
da
Mostra 5 altri commenti
Aggiungi un commento
1 Risposta
its 1 of 3 things u have a loose LCD or not connected properly it could be that u have attempted to mess with the power management by accident and now it's has too much/&or to little voltage and is ether broken or not working properly, or 3 it's something on the board that's needs replacing these are the most common things i run into
Punteggio 0
Aggiungi la tua risposta
Frank Lovash sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 31
Tutti i Tempi: 4,241
