Salta al contenuto principale
The Lenovo ThinkPad S431 is a laptop with an aluminum exterior. It can be identified by looking for the model number "S431" on the right top corner of the keyboard. The ThinkPad is 0.8 inches thick and has a touch-enabled display.
Why my laptop is not opening
Why Laptop is not opening, i press a power button many times but didn't show anything
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Hi
Does the laptop show that it is charging when you connect the charger?
da
Yes, it is charging but the laptop is not opening
da
Aggiungi un commento
1 Risposta
There are many reasons.
1.Short Circuit. Due to a short circuit, you maybe need to change your motherboard. Maybe only
2.Loose cables or disconnected. Note: a laptop won't work until you connect the fan
These are the reasons I could think of hope it helps you
BY AADHITHYA MATHAN
5TH STANDARD
CHAITANYA TECHNO SCHOOL
Punteggio 0
Aggiungi la tua risposta
Sachin Goswami sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 143
