Salta al contenuto principale
Ci sono così tante cose che potremmo fare se solo sapessimo come. Quest'area si propone di catalogare le competenze più specialistiche necessarie per eseguire determinati tipi di riparazioni.
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
da
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thanks for the advice oldturkey03 :D
Here's that: iFixit 26 Bit Driver Kit Technique for Removing Bits
Punteggio 1
1 Commento:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
da
Preparati per le riparazioni future
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
Punteggio 0
Aggiungi la tua risposta
aaronmiller sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,713
