Salta al contenuto principale
iFixit 26 Bit Driver Kit Technique for Removing Bits
Cosa ti serve
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 1, immagine 1 di 1
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 2, immagine 1 di 1
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 3, immagine 1 di 1
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Conclusione
Altre 49 persone hanno completato questa guida.
aaronmiller
Membro da: 08/28/11
1.394 Reputazione
1 Guida realizzata
2Commenti sulla guida
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Replica
I just use the included bit driver. Once removed, reverse it and I am ready to go!
P.S. Anyone got a guide on how to fix the hinge. Spring is loose and the bit tray is out.
Harold - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 50
Tutti i Tempi: 5,813
