Salta al contenuto principale
Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2011. Identified by model number A1395 and EMC 2415. Repairs require the use of heat and careful prying.
iPad 2 replacement battery missing a chip compare to original
Just ordered replacement battery for iPad2, found out that the new battery is missing a chip compare to the original. Anyone knows what is the chip function on the battery? I've checked the ifixit replacement battery, it doesn't have the chip as well. Will it affect the functionality of the battery?
Refer the image, left new battery, right original.
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
This will not be a problem.
Punteggio 1
2 Commenti:
Hmm really? How do you know. I'm really curious the functionality of the chip on the original battery.
da
@mirror less I think it tells the iPad that the battery is original.
da
Hi
If I saw this I would be alarmed too but not to worry because you shouldn’t be
The reason why the chip isn’t there is because different battery manufacturers have different ways of designing and managing their battery’s I have had iPod touch screens that look completely different and perform nearly identical to the original(apart from small colour differences)
But to sum it all Up I wouldn’t be worried unless you plug it in and it doesn’t work but that’s rare and it will probably work really really well!
Hopefully I answered your question
Punteggio 1
Aggiungi la tua risposta
mirror less sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 34
Tutti i Tempi: 373
