Salta al contenuto principale
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
What do I need to purchase if I want to replace the HDD with an SSD?
Looking to replace the HDD in my iMac with an SSD. I have an SSD on hand but want to know do I need to purchase anything such as a temp sensor? I know older models needed some after market temp sensor otherwise the fan would run at 100% all the time. Is this still the same with this model or am I able to replace it without purchasing a sensor? What else would be recommended to make this process easier? I know I will need the little cutter that ifixit sells and some new adheasive. Any recommendations are also welcome.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Here’s the guide Sostituzione hard drive iMac Intel 21.5" EMC 2889
You don’t need any thermal sensor for your system, But I strongly commend you get the tools and sundry items listed out here iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit And make sure you follow the guide to the letter using the special cutter wheel as many people have damaged their display using the wrong tools.
Immagine Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit.
Prodotto
$55.99
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Dudefoxlive sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 122
