How to reset the anti theft system
How to reset your anti theft system in a 2001 Grand jeep Cherokee Laredo
Questa è una buona domanda?
Step 1
Enter your Jeep and press the Lock button on your keyless remote five times in 10 seconds.
Insert your key into the car's ignition, turn it to the "Run" position and wait for the car's chimes to stop.
Press and hold the "Unlock" button on your remote, and then press and hold the "Panic" button while still holding "Unlock." Hold both buttons together for one second and release.
Wait for a chime to sound and press and release the "Lock" and "Unlock" buttons on your remote.
Press and release the "Lock" button by itself and wait for the car's chimes to sound again to indicate successful resetting. Remove the key from the ignition when you are done to finish the procedure.
Will this work if the jeep stopped recognizing the key?
which button is the"panic
' button?
doug, on the key fob https://www.amazon.com/Electronic-Keyles...
I tried the above procedure it does not work is there any other options
it did not work on my 2005 Jeep Liberty nothing works on it I've tried every thing out there somebody help!!
Preparati per le riparazioni future
2004 jeep grand Cherokee laredo don't have key fobs. How do I disable it?
Replaced pcm programmed to ignore disabled/ removed skim in 99 grand cherokee. It now runs with any key cut to fit. Alarm still flashes exterior lights. Don't have key fob anymore but want to disable Alarm now. Ideas?
Ultime 24 Ore: 14
Ultimi 7 Giorni: 85
Ultimi 30 Giorni: 413
Tutti i Tempi: 63,146
6 Commenti
Did you review previous questions with answers related to your Grand Cherokee, the box on the right?
da F Dryer
Mine wont start at all. Battery ok. It's 2021 Jeep Rubicon. Cant shift out of park etc
da paula madine
This did not work on my 2002 jeep liberty sport.
da Shawn Melvin
This doesn’t work on 08 Wranglers
da Charles McCannon
Didn't work on my 2004 jeep grand cherokee
da juancgomez040783
Mostra 1 altro commento
