Salta al contenuto principale
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
How to reset the anti theft system
How to reset your anti theft system in a 2001 Grand jeep Cherokee Laredo
Questa è una buona domanda?
Punteggio 6
6 Commenti
Did you review previous questions with answers related to your Grand Cherokee, the box on the right?
da
Mine wont start at all. Battery ok. It's 2021 Jeep Rubicon. Cant shift out of park etc
da
This did not work on my 2002 jeep liberty sport.
da
This doesn’t work on 08 Wranglers
da
Didn't work on my 2004 jeep grand cherokee
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Step 1
Enter your Jeep and press the Lock button on your keyless remote five times in 10 seconds.
Step 2
Insert your key into the car's ignition, turn it to the "Run" position and wait for the car's chimes to stop.
Step 3
Press and hold the "Unlock" button on your remote, and then press and hold the "Panic" button while still holding "Unlock." Hold both buttons together for one second and release.
Step 4
Wait for a chime to sound and press and release the "Lock" and "Unlock" buttons on your remote.
Press and release the "Lock" button by itself and wait for the car's chimes to sound again to indicate successful resetting. Remove the key from the ignition when you are done to finish the procedure.
Punteggio 5
17 Commenti:
Will this work if the jeep stopped recognizing the key?
da
which button is the"panic
' button?
da
I tried the above procedure it does not work is there any other options
da
it did not work on my 2005 Jeep Liberty nothing works on it I've tried every thing out there somebody help!!
da
Mostra altri 12 commenti
2004 jeep grand Cherokee laredo don't have key fobs. How do I disable it?
Punteggio 0
Aggiungi la tua risposta
MEGAN Jewell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 142
Ultimi 30 Giorni: 557
Tutti i Tempi: 61,620
