Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
replacing my iMacs gpu
Right now my iMac has the Radeon HD 5750. Due to freezes and failures, i have decided to replace the gpu.
1. What are my options (graphic cards) regarding the GPU replacement?
2. Will the Ati HD 6750 work seamlessly?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your official choices for your system
  • ATI (AMD) Radeon HD 5750, 512 MB V-RAM, Apple P/N 661-5578
  • ATI (AMD) Radeon HD 5750, 1 GB V-RAM Apple P/N 661-5579
2011 MXM boards
  • AMD Radeon HD 6770, 512 MB V-RAM Apple P/N 661-5567
  • AMD Radeon HD 6970, 1 GB V-RAM Apple P/N 661-5568
  • AMD Radeon HD 6970, 2 GB V-RAM Apple P/N 661-5569
The problem is finding one that is still working! Many people pushed their systems harder than these GPU boards where designed to support running heavy graphics tasks.
Also keep in mind the Apple boards have special firmware, unless you know how to burn the EEROM its best to stick with the real ones.
Punteggio 1
2 Commenti:
Thanks Dan...
1. What are MXM boards, and what do they have to do with my issue?
2. Will they work seamless if installed on my iMac?
3. What do u mean by "stick with the real ones"?
da
Review this guide Sostituzione scheda grafica iMac Intel 27" (fine 2009 o metà 2010)
This series uses a MXM board assembly which holds the GPU chip its self. As you can see it's quite a bit of work!
Apple uses custom firmware on these boards held in a small EEROM chip. So getting a Dell board or other system MXM board won't work without the firmware on the board being replaced. Only the real Apple boards will work seamlessly without alteration which in its self is a bit of work flash any video card bios NVIDIA or AMD without fear of bricking
Your questions imply you haven't working on a mac this deep. Maybe its best to seek out someone who has.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
genik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 615
