Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
The HP Elitebook x360 1030 G2 is a 2-in-1 device serving both as a laptop and tablet. This page contains repair guides, maintenance and service information, and a troubleshooting manual related to the HP Elitebook x360 1030 G2. Battery model number: 1GY30PA
Is the RAM upgradeable?
I wanted to upgrade the RAM, but I can’t find it in the laptop. Is it on the MB?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
HPs documentation indicates that the RAM on this model is soldered onto the board. So for all intents and purposes, no it is not user upgradeable.
Punteggio 3
2 Commenti:
What if the RAM fail? My computer RAM Failed but not removable
da
@Biruk Ayele You might be able to find a repair technician who does board level repairs that can diagnose the issue and replace either the RAM chips themselves, or whatever faulty component is causing the problem.
Otherwise you'll have to replace the system board to restore functionality.
da
Parti & Attrezzi Popolari
This seems to be factory configured
About your EliteBook x360 1030 G2
Your computer's memory capability:
Standard memory:
4GB to 16GB non-removable”
Punteggio 1
2 Commenti:
"The HP EliteBook x360 1030 G2 comes with 8GB DDR4 RAM on board, and there is no spare RAM slot, so you can not upgrade the RAM."
da
HP EliteBook x360 1030 G2 Disassembly (SSD, RAM Upgrade Options)
A pretty detailed tear down https://www.laptopmain.com/hp-elitebook-...
da
Nope, it's on the MB.
Punteggio 0
Aggiungi la tua risposta
Richard J sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 96
Tutti i Tempi: 10,116
