Salta al contenuto principale
L'HP Elitebook x360 1030 G2 è un dispositivo 2-in-1 che funge sia da laptop che da tablet. Questa pagina contiene guide di riparazione, informazioni su manutenzione e assistenza, e un manuale di soluzione problemi relativo all'HP Elitebook x360 1030 G2. Numero di modello della batteria: 1GY30PA
Is the RAM upgradeable?
I wanted to upgrade the RAM, but I can’t find it in the laptop. Is it on the MB?
Questa è una buona domanda?
Punteggio 0
2 Commenti
i want to upgrade my hp g2 ram it is 8 GB and i want to make it 16 GB so how can you help me with? I usually not meet some softwares requirement what should i do
da Condividi
@goodlucknelson Check the answers. The short answer is that you can't. The RAM is soldered onto the board, making it a extremely difficult replacement process. Not impossible, just not worth the risks.
da Condividi
Aggiungi un commento
3 Risposte
Soluzione prescelta
HPs documentation indicates that the RAM on this model is soldered onto the board. So for all intents and purposes, no it is not user upgradeable.
Punteggio 4
2 Commenti:
What if the RAM fail? My computer RAM Failed but not removable
da Condividi
@Biruk Ayele You might be able to find a repair technician who does board level repairs that can diagnose the issue and replace either the RAM chips themselves, or whatever faulty component is causing the problem.
Otherwise you'll have to replace the system board to restore functionality.
da Condividi
This seems to be factory configured
“About your EliteBook x360 1030 G2
Your computer's memory capability:
Standard memory:
4GB to 16GB non-removable”
Punteggio 1
2 Commenti:
"The HP EliteBook x360 1030 G2 comes with 8GB DDR4 RAM on board, and there is no spare RAM slot, so you can not upgrade the RAM."
da Condividi
HP EliteBook x360 1030 G2 Disassembly (SSD, RAM Upgrade Options)
A pretty detailed tear down https://www.laptopmain.com/hp-elitebook-...
da Condividi
Nope, it's on the MB.
Punteggio 0
Aggiungi la tua risposta
Richard J sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 33
Ultimi 30 giorni: 77
Tutti i Tempi: 11,807
