Salta al contenuto principale
Released by Nikon in January 2014, the Coolpix L830 is a compact digital camera designed to provide powerful zoom with simple operation.
Why It only turns on with the power supply?
Nikon coolpix L830 started to place messages , card can not be read., i turn it off them On and it worked.
Now the camera does not turn on with the batteries , I plug it to the power supply and that's how it works.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
batteries can be bad enough that they appear to be fully charged in the charger but have such a high internal resistance that the terminal voltage under load won’t run anything. If u really want to test it u must put a load across your DVM probes and connect to the output terminals.
Punteggio 0
1 Commento:
How i do it? A have a DVM and i have try several testing. Batteries are new and the charge is ok.any other tips?
da
Aggiungi la tua risposta
Angel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 170
