Salta al contenuto principale
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
Canon EOS60D USB Interface Board Replacement.
My Canon EOS60D was on a tripod with USB cable in place. Tripod was knocked over and camera landed on the Port side, meaning that the USB plug hit the floor first. Since then the USB connection has not worked although all other camera functions are fine including HDMI interface and remote trigger.
Is it possible to replace the USB interface board and if so, how? I’ve looked at your guides and none go as far as accessing the USB board.
Thanks in advance
Harry Watson
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hello!
Thankfully (since cameras are so pricey) they are generally repairable. However, parts can be difficult to find, especially for a camera of this age. Have you tried contacting either Canon support, or a local camera store? They will likely have parts, or be able to repair the board themselves. If they cannot, you could try to solder a new USB connector to the PCB. In the meantime (or if you determine it isn’t possible, too expensive, or too risky to try and fix the USB) try removing your SD card and read the data off of it.
Punteggio 1
1 Commento:
All this is good advice. Thanks for answering.
da
Aggiungi la tua risposta
Harry Watson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 222
