Salta al contenuto principale
What ram to choose?
I have an 8 GB CL17 2667 MHz currently installed want to make it 16 GB. I found a CL19 2667MHz 8GB Crucial RAM will it work? Will there be any problems when installing 2 different RAMs of CL17 and CL19?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
You can only try and see if it works OK.
If it works OK it will work at the slower latency speed of CL19 (14.25 nano seconds) as opposed CL17 (14.17 nano seconds) which is only marginal.
If you encounter problems you may have to get two modules having the same specifications.
Here’s a link that may help explain it better than I can. (note: CL= CAS)
Punteggio 1
Aggiungi la tua risposta
jabebrwocky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 159
