Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to replace Home button flex cable
Does anyone know how to repair the flex cable for the home button. One of the spring-loaded contacts broke which I fixed with a spot of solder and a small metal prong. However I am banking it won't last forever so would like to replace the flex cable at some point.
The bit I need to replace is this
http://www.digiexpress.us/iPhone-3G-Home...
I am guessing I'll need to get the plastic button out then insert this through the hole in the top case, but how does the home button pop out?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The home button is held in by the glass digitizer - there are tabs on the left and right sides of the button.
This picture has a pretty good view:
http://s1.guide-images.ifixit.com/igi/RI...
So, if you need to replace the home button itself, you are going to have to remove the digitizer, and will need these to adhere it back in place:
http://www.ifixit.com/iPhone-Parts/iPhon...
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
solarisjon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 12,543
