Salta al contenuto principale
Questa pagina include guide per la riparazione e recensioni tecniche del Huawei Mate 10 (rilasciato a novembre 2017).
Battery compatible with Mate 10 Lite?
Does anyone know if the battery ifixit sells for the mate 10 is also compatible with the mate 10 lite?
https://store.ifixit.de/products/huawei-...
There’s no battery explicitly for the lite version. It’s so %#*@ hard to find the actual battery specifications of the phone, I just found the capacity which is higher in the above battery.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @kryptojude ,
They are different batteries.
The model number shown for the Ifixit battery that you linked is HB436486ECW (printed on battery)
The model number of the battery in a Huawei Mate 10 Lite as seen in this video is HB356687ECW - see image taken from video.
They have different dimensions and capacities and I don’t know if they have the same pin out connections in the battery cable.
Mate 10 battery dimensions = 4.3mm x 64mm x 86mm, rated capacity 3900mA
Mate 10 Lite battery dimensions = 3.5mm x 66mm x 87mm, rated capacity 3240mA (actual capacity 3340mA)
Here are the full specifications for the phone
(click on image to enlarge for better viewing)
Punteggio 3
1 Commento:
Thanks a lot!
da
Aggiungi la tua risposta
Kryptojude sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 517
