Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
What is the TG0B sensor?
Does anybody know what the TG0B sensor is and what could cause thermalmonitord returning “not alive” with context SD: 0 BC: 1 Missing sensor(s): TG0B
When that happens, the shown battery filling level drops to 0% and shortly after it will reboot with the mentioned error in the panic logs.
First I suspected that the error might be related to the lightning port. But replacing it didn’t fix it.
Questa è una buona domanda?
Punteggio 3
3 Commenti
hi if you solve this problem please tell me what you replacing!
da
Hello , I am facing the same problem with my iphone . If you have solve this problem ,can you tell me by replacing what you solve this problem?
da
@mehrajsalfi Start by following @oldturkey03's advice and replace the battery. As he said, sensor TG0B is located on the battery, so that's the place to start.
The sensor is read by two signals that pass through the battery connector and through a couple of components mounted next to the connector. Occasionally a component will get knocked off the board in the process of connecting and disconnecting the battery, which can cause that same error.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@mfmayer start by replacing the battery. If you already have done this, check the components around the battery connector. Make sure you did not pop one off. Those can be causes for this as well. Ultimately “SD: 0 Missing sensor (s): TG0B” - battery / TIGRIS; result is that the device does not see the battery.
Punteggio 5
Preparati per le riparazioni future
Acquista tutti
Go get new phone for nothing and sign new contract for 2 years and pay what you would anyway with old phone and contract..Best solution...
Punteggio 0
1 Commento:
@markmiller17834 iFixit is about repair and keeping things out of the landfill. WE are here to empower people to fix their devices not to purchase more and thus further increasing eWaste. BTW there is no "new phone for nothing", it all costs you money. There is no such thing as a free lunch.
da
Aggiungi la tua risposta
Matthias sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 201
Tutti i Tempi: 13,604
