Salta al contenuto principale
Tutto quello che ti serve per riparare da solo il tuo iPhone con guide gratuite di riparazione e parti di ricambio e attrezzi di qualità! Dalla nuovissima linea iPhone 16, fino all'iPhone 2G originale del 2007, iFixit offre guide di riparazione gratuite e informazioni sullo smontaggio per ciascun modello di iPhone.
Face id and fingerprint button Replacement with programmers
After looking into buying an iphone programmer i am between the JC V1s (more expensive) and the Qianli icopy Plus 2.1 (cheaper),
I know that the JC V1s is ‘‘able’’ to program the dot projector from the face id and the fingerprint scanner of some JC buttons and do many more…
But my biggest question is if this means that i can SIMPLY REPLACE the damaged face id sensor with the whole front camera module by programming a new one?
As for the fingerprint buttons i have heard that some times it does and some times doesn’t work.
What do you know about the subject of face id and fingerprint replacement using the JC V1s programmer?
Also do you have any suggestion on witch programmer to buy because if its not easy to replace the face id and fingerprint i think that the icopy programmer makes more sense.
Thank you!
Questa è una buona domanda?
Punteggio 0
2 Commenti
No you can’t replace the full module, the programmer is only for reading and writing flex cable data to a new flex like the i2c flex. As for home button I’m not to sure of.
da
I understand what you mean... Thank you very much !!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Daniel is right about only writing to the flex. You will still need good microsoldering skills to remove the eeprom and transfer other components.
The home button function only allows the reading and writing of the serial number it does not bring back touch ID.
Punteggio 3
3 Commenti:
ohh i see so its not an easy case of out with the old in with the new.
And i understand whats going on with the home button...
So thank you both very much!
da
so then.... JC V1s or Qianli icopy Plus 2.1 ?
da
Yo creo que la Qianli es más barata y hace las funciones rápidas de copiar lcd y bateria info que es para lo que la vas a usar más.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Engineering sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,828
