Salta al contenuto principale
Modello A1418 / Fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
Spec for the installed Blade SSD
In the RAM comments, I asked what upgrade I could do for the blade SSD.
OWC blade (right connector configuration) in a higher size?
I’m putting in an SSD for the 3.5” and want the second dive (blade) as a second drive. Fusion is not wanted the 3.5” SDD is faster. Any spec for the installed Blade SSD?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your iMac uses a mSATA III (6.0 Gb/s) blade interface. Here’s the drive options for your system OWC Aura 6G mSATA III Blade SSDs
Reference: The Ultimate Guide to Apple’s Proprietary SSDs Review Generation 2 listing.
Punteggio 1
1 Commento:
My Mac parts supplier (Beetstech in Chico, CA had a used Apple SSD) placed that into the unit, all works fine. Thanks for you insight.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Carl Schultz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 82
