Salta al contenuto principale
Modello A1418 / Fine 2012 / Processore Core i5 da 2,7 e 2,9 GHz o Core i7 da 3,1 GHz
Spec for the installed Blade SSD
In the RAM comments, I asked what upgrade I could do for the blade SSD.
OWC blade (right connector configuration) in a higher size?
I’m putting in an SSD for the 3.5” and want the second dive (blade) as a second drive. Fusion is not wanted the 3.5” SDD is faster. Any spec for the installed Blade SSD?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your iMac uses a mSATA III (6.0 Gb/s) blade interface. Here’s the drive options for your system OWC Aura 6G mSATA III Blade SSDs
Reference: The Ultimate Guide to Apple’s Proprietary SSDs Review Generation 2 listing.
Punteggio 1
1 Commento:
My Mac parts supplier (Beetstech in Chico, CA had a used Apple SSD) placed that into the unit, all works fine. Thanks for you insight.
da
Aggiungi la tua risposta
Carl Schultz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 111
