Salta al contenuto principale
The second generation (KK) Jeep Liberty, a compact 4-door SUV that restored the classic sharp lines of the original Jeep styling.
42RLE Code (DTC) P0732 Gear Ratio Error in 2nd
Only in the morning star the car trans in D move and get have issues on second gear, check engine light up sometimes but not often, if I wait and warm up the vehicle for at list 15 min I have no problems, if I need to go i have the problem about 1 or 2 times and then nothing, if warm car runs perfect no issues, if cold same problem all the time just one or two times and then runs grate, I have the 2012 Jeep Liberty, my ex-wife has a 2011 same problem… we change filters, oil, service differential, maintain car in 100% on Jeep check service but this problem is getting on my nerves please advise….
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @vikugo ,
When you say that "..we change ..... oil, .......", do you mean the transmission fluid or the engine oil?
The ATF needs to be changed every 100,000 miles.
If the transmission fluid is clean and doesn’t smell burnt and is the correct level it may be a problem with the 2nd gear, shift solenoid in the transmission.
Punteggio 1
Aggiungi la tua risposta
Victor Hugo H Jimenez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 557
