Salta al contenuto principale
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
I have a problem with the processor fan working
When I turn on the device, I hear a violent sound of the fan that lasts for 4 seconds, with the device vibrating violently And also when I play or do a task on the device, knowing that I have cleaned the dirt.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
Here’s the service manual for the laptop.
Go to p.75 to view the necessary pre-requisite steps and then the procedure to remove the thermal cooling assembly. This will give you access to the fan so that you can check if it is OK (clogged with dust?) or if it is faulty and needs to be replaced.
If it is faulty then replacement fans are available online. Just search for Dell Inspiron N5110 fan or use the information from the label on the fan itself, to find suppliers that suit you.
Punteggio 0
Aggiungi la tua risposta
Forg Eex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 66
