Salta al contenuto principale
Repair and disassembly guides for doors and windows.
How to adjust uPVC window door?
I moved to this new flat, and there seem to be an air leak from the balcony window, the leak only goes from the side where the hinges are! is there anyway to tighten the door so it could be sealed, i must mention that the rubber seals are brand new and the main issue here is that the window is not adjusted right, only problem is how to make that adjustment?
Questa è una buona domanda?
Punteggio 0
1 Commento
How to slowly window 2 side lock problems?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
hi @sureno ,
This link may be of some help.
Punteggio 1
6 Commenti:
the door seems to have a butt hinge type, now I am not sure if I am able to adjust the compression from the hinge's side, but if I do adjust the one from the lock side will that tighten the seal for all sides of the window? or will it only compresses it from the lock side alone!?
da
@sureno
It may be a case of trial an error to see if you can get it right as there isn't too much adjustment in a butt hinge.
Here's another link that may help a bit more
da
Alright, appreciate the input. I will do try that, I am trying to get the theory right first, in order not to screw anything up as the windows are newly installed :). thanks a lot for your help @jayeff !
da
I will definitely try your link. I will let you know if this one work. Thank you!
da
@sureno
if they were newly installed by a professional company and not by you, call them back to fix it as it wasn't done correctly if there is a gap that allows a draft through
da
Mostra 1 altro commento
Parti e strumenti correlati
Aggiungi la tua risposta
Sureño sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 129
