Salta al contenuto principale
ATX Mid Towers have the same general build and parts as other mid size computer towers
New build, No post
Question
Just started a build this morning, getting power to board, fans are spinning but it won't post at all, I've taken it apart multiple times and completely reassembled. I'm running on an Asrock b450m motherboard.
Have rinserterd ram multiple times and cleaned it as well.
Any help is much appreciated.
Thanks in advance
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi,
Have you connected a system speaker to the appropriate motherboard header pins to hear if there is a beep error code when starting?
See this answer as it has links for a Asrock B450 Pro 4 manual which should be nearly the same at least for system speaker connection and error codes. Assistance with diagnosing my mystery fault
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Fixed, old cpu was a ryzen 5 apu with integrated graphics. New one did not have integrated graphics *facepalm* installed gpu and everything is posting and working fine.
Thank you for any and all help.
Punteggio 1
1 Commento:
We all have duh! moments. But it is working now. Good one!
da
Risposta Più Utile
You didn't give us very many details.
For starters:
  • What CPU do you have and is it on the ASRock CPU support list for your motherboard?
  • What version is the BIOS?
  • Is the RAM ion the ASRock support list?
Look on the ASRock website's support for your motherboard.
Punteggio 2
Aggiungi la tua risposta
Cole Walker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 124
