Salta al contenuto principale
Broken electronics ID question
I bought this off of a guy who said it was working then stopped. This part on the PCB is damaged. I need to know what it is so I can replace it. I do have the skills and tools to replace it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Joshua Powell
That is an inductor, i cannot see the values well in your picture.
e,g. you can can search in electronics component stores, like element14, digikey, etc e.g. value, 1R0 inductor.
else you also can get from aliexpress, ebay, etc
Punteggio 1
6 Commenti:
thanks! i was looking but needed a second opinion before i did anything else.
da
Hi Joshua
No worries, you are welcome. the inductor is cracked.
try replacing and see if it works!
da
the inductor has 280 or something like that printed on it
da
@Joshua Powell that number is actually pretty important. It shows how many Henries your inductor is rated for. Three digit values are in nano Henries or micro Henries depending on manufacturers choice. The first 2 digits are the value and the 3rd digit is the multiplier. If yours shows 280 that means it has an inductance of 28 µH (28x0=28)
da
Mostra 1 altro commento
Aggiungi la tua risposta
Joshua Powell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 195
