Salta al contenuto principale
Windows 10 è una versione principale del sistema operativo Windows. È stata rilasciata nel 2015.
My computer will not turn on
My computer has been having problems for well over a year now. A while ago it would not turn on unless it was plugged in so I started using my moms battery and my computer would turn on then but it would shut off later on. The battery works perfectly fine on her computer but not on mine.My computer will now absolutely not turn on at all. I'm thinking there is something wrong with the inside of the computer but I have no clue what.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Hi @na7a133
Let us know the exact model of your computer, so we can check and provide you with better advises to check on it.
There could be some hardware issues on your computer.
da
@na7a133 my only guess is to replace your battery, since im guessing you use it alot
da
Aggiungi un commento
1 Risposta
Since you are able to use your laptop when it is plugged-in, more than likely its good and your battery has reached its end of life. You may look at the specs on it and see what the supply output voltage is and check it with a multi-mete. Replace your battery and it should all be fine.
Also make sure to check out these methods the post provided.
https://www.minitool.com/data-recovery/f...
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Natalee Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 175
