Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
Problems with screen after long time not using
Had it lying around for about 1~2 years. After charging up and open back the screen turns into some water-ish damage almost entire screen while the edges still looked normal.
Is the screen panel damaged? Or is it some steam trapped between screen panel and glass panel?
Questa è una buona domanda?
Punteggio 0
1 Commento
You'll need to plug in an external monitor to be sure you don't have anything deeper.
If you are able to get it going enough I would also check your battery as it likely needs replacing, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I have seen this before; unfortunately, your LCD has suffered permanent damage. I can’t give you an exact reason why this happens, as there are many, but in most cases, this can be attributed to either too much heat or pressure on the display. If this machine was sitting somewhere that gets a lot of sunlight, or stacked beneath other items for a prolonged period of time, this problem will develop.
You will need to replace the LCD or the entire display assembly (whatever you’re more comfortable doing).
Sorry for the bad news.
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Lee Han Chang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 112
