Salta al contenuto principale
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
How to replace the USB charging port?
I have a Bose SoundLink Color, the USB charging port and the 3.5 mm jack are encased in this black piece of plastic, which does not seem extractable although it has two plastic pins visible from the other side.
How do you suggest to proceed?
Questa è una buona domanda?
Punteggio 1
1 Commento
I am having this exact same issue right now. Guess my plan is to desolder the combined usb and aux component, then see if I can open it up, and eventually replace the USB part. Maybe solder new wires on the other side of the right pins and drill a hole in the side for a brand new duplicate USB port.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@hyklamin that is correct. The replacement comes like that. Here is the bad part, those are really hard to find and you may need to find a broken Soundlink to harvest that connector from there. Or, if you know somebody who can do 3D printing, make your own plastic casing with some options to slide a replacement USB port etc., into it. Then get some connectors from places like Mouser or Digikey and rig it up. PITA but doable. this is going to be more a re-engineering than a straight replacement.
Punteggio 1
1 Commento:
I am actually asking how to reach the base of the component I want to desolder. I can only think of melting the plastic.
da
Parti & Attrezzi Popolari
hola . tengo el problema con el parlante , que no carga ni enciende,pude desconectar la bateria y tiene carga. entonces para mi la bateria no es el problema. estoy revisando componentes a ver que encuentro. adios.
Punteggio 0
Aggiungi la tua risposta
Yklamin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 49
Tutti i Tempi: 3,357
