Salta al contenuto principale
Guide di riparazione e supporto per tutti i ventilatori meccanici domestici, inclusi ventilatori da soffitto, box, a torre e con il piedistallo.
Box fan makes zingzing sound
My Robeson box fan stopped working, meaning I could hear the motor hum but the blades did not rotate. I removed the blade assembly, cleaned out the dust and oiled the motor. I tested the fan without attaching the blades. The motor seemed to work. After I put the blades back on again, I hear a zing-zing sound. How can I fix this?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @anupm12
If you hear the motor hum and it does not spin well, I suggest you to check on the fan capacitor first. It should not crack / bloat or leak.
da
Augustine, after the cleaning and oiling the motor (with blades removed) does spin properly with no strange noises. When the blades are installed, the motor still spins but I hear a constant zing-zing sound. The capacitor is not cracked, bloated nor leaking.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @anupm12
With the blades on, when manually spinning them, looking from side on i.e. not from the back or the front, are they turning in a fixed plane or wobbling about due to a bent rotor shaft or faulty bearing that is only noticeable with the weight of the blades on it?
Punteggio 1
7 Commenti:
Jayeff, I don't detect any wobbling.
da
@anupm12
Does it make this noise when the fan is outside of the protective cage or only when installed inside it?
da
The motor and blades remain within the box (protective cage). I did remove the front and the back grills in order to make repairs.
da
@anupm12
So the blades aren't hitting the box at all (side/front) as they turn?
Are the blades all at the same angle away from the centre point?Just wondering if one were at a different angle (twist?) that it may cause the air to make a different sound
da
The blades are not hitting anything. One of the blades is twisted when compared to the other two. However the zingzing sound is metallic and not a swish of the air sound.
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Anup sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 423
