Salta al contenuto principale
Dell Precision is a series of mobile and fixed computer workstations designed for professional consumers and CAD/Architecture/CG professionals, or as small-scale business servers.
Crack on socket pin of RAM DDR4
Dear Team,
I have one problem need your help.
My laptop is Dell precision 5520, one socket of RAM have carck at the pin No.145. This pin is weak and not good in touch to RAM pin .Laptop usually stop working when has shock.
(Pin No.145: Bank address inputs: Define the bank (with a bank group) to which an ACTIVATE, READ, WRITE, or PRECHARGE command is being applied. Also determine which mode register is to be accessed during a MODE REGISTER SET command)
Please have look attached photo and help me how to fix this issue. I want to hear your advice on this matter.
Here is the link of this RAM datasheet:
https://www.micron.com/-/media/client/gl...
Thanks a lot!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @taile ,
Maybe a bit desperate but have you thought about filling the gap with conductive glue - info only?
Punteggio 1
1 Commento:
@jayeff
Thank you for your advice!
This is a good idea. However the gap is very small, i afraid the conductive glue will spread out and make short circuit for RAM and CPU and the pin will stick/fix to plastic, affect to RAM when insert to the socket.
da
Aggiungi la tua risposta
Tai Le sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 108
