Salta al contenuto principale
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
GPS and Bluetooth not working after screen replacement
Hello there, a few months ago I replaced the screen of my Xiaomi A2. I also had to change the phone’s casing.
After some tests, however, I noticed that the bluetooth and the GPS were not working.
I can’t pinpoint what happened, since everything else is working fine and I can’t find a particular piece of hardware missing or apparently damaged.
Maybe I’ve missed some small detail. Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @valp ,
By not working do you mean that they couldn’t be turned on or that they showed no indications of receiving a signal?
Does the WiFi also not work?
If it is also not working or only working when the phone is placed nearly on top of the router then there maybe a problem with the WiFi/BT antenna connection. (The BT might also register if placed right next to a BT device)
Here’s the ifixit Xiaomi Mi A2 USB Port Replacement guide. I realize that this is not the problem but the guide is useful as one end of the antenna connection is able to be seen in the image at Step.8 in the guide. You would have to trace it back to check if the other end was also connected securely if the end near the USB port was OK
The antenna connection is also visible in the image below. Look for the black cable with the silver connector coming down a channel on the left side the bottom of the image.
Punteggio 1
Just go and solve your problem
Mi a2 bluetooth problem solution
Hope this will help you
Punteggio 0
Aggiungi la tua risposta
Victor Dude sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 544
