Salta al contenuto principale
The Acer Aspire laptop is a personal computer that can be identified by its model number 5349-2592. The laptop uses Windows 7 and has 250 GB HDD of memory to be used by a user.
2 Domande Visualizza tutte
Cpu upgradability and which cpus are compadible
i want to upgrade my slow cpu on my acer aspire 5349 . because i havent done this yet i want to know if this is possible and which cpus and what to be careful(bios and stuff). thanks for the answer
Questa è una buona domanda?
Punteggio 1
1 Commento
Series Acer Aspire 5349/Aspire 5749/Aspire 5749 Z
Are the NTBs the same (they differ from the installed CPU from the factory) They have a CPU in the G2 socket. It is therefore possible to install a Sandy Bridge CPU for socket G2. Max CPU by performance class: Celeron B840, Pentium B980, Core i3-2370M, Core i5-2540M, Core i7-2640M, Core i7-2960XM. BUT I RECOMMEND TO OBSERVE TPD 35W for CPU considering the cooling performance. Therefore, the "most powerful" is the Core i7-2640M.
And one more note. Acer recommended 8GB of RAM for these notebooks, but all CPUs and motherboard chipsets support 16GB of RAM.
If you have the original CPU or a CPU upgrade, you can fit DDR3 SODIMM 2 x 8GB RAM and you have 16GB RAM.
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Hi,
You cannot upgrade the CPU in the laptop as it is hard mounted onto the motherboard.
Here’s a video that shows how to disassemble the laptop which is useful because you can see at the 7.29 minute mark into the video (also from 9.29 onwards) that the CPU is not removable.
If you wish to improve the laptop’s performance you can upgrade the RAM to 8GB and replace the HDD with a SSD
Here’s a couple of links that may help with that.
Acer Aspire 5349-2592
parts supplier (only shown for what is compatible and the cost. There are other suppliers that may suit you better. Just use the specifications provided.)
Punteggio 2
4 Commenti:
ive oppened the laptop and i can remove the cpu(maybe i have a different different model of acer aspire 5349?) so i was more wondering which cpus can be compatible with motherboard or there are none
da
@Aleksandra Hribernik ,
What is the full model number of your laptop?
da
Acer Aspire B815/2/320
da
You have given the model number of the CPU. It is a Celeron B815/2/320.
What is necessary is the model number of the laptop. This should be on a label under the laptop in even in the BIOS
da
Series Acer Aspire 5349/ Aspire 5749 / Aspire 5749Z
Punteggio 1
1 Commento:
Here is a list of compatible (usable) Sandy Bridge CPUs for the G2 socket for the Acer Aspire 5349, 5749, 5749Z and their use is not blocked by the bios (by Acer).
There are still a few Sandy Bridge CPUs for the G2 socket, but they already have a TPD of more than 35W, and I don't know of anyone who has tried them, so I don't recommend using CPUs other than those listed.
Celeron B710
Celeron B720
Celeron B730
Celeron B800
Celeron B810
Celeron B815
Celeron B820
Celeron B830
Celeron B840
Pentium B940
Pentium B950
Pentium B960
Pentium B970
Pentium B980
Core i3-2308M
Core i3-2310M
Core i3-2312M
Core i3-2328M
Core i3-2330M
Core i3-2332M
Core i3-2348M
Core i3-2350M
Core i3-2370M
Core i5-2410M
Core i5-2430M
Core i5-2450M
Core i5-2520M
Core i5-2540M
Core i7-2620M
Core i7-2640M
da
This one
Punteggio 0
4 Commenti:
Hi
You have the Acer Aspire 5349 so the answer above also applies to your laptop.
All Acer Aspire 5349 models are the same in that the CPU is hard mounted onto the motherboard and cannot be replaced.
da
how come i could removed it then from the socket?
da
OK then I was wrong. Apologies
So was it held in by a screw?
What information is written on the CPU?
If you know the CPU full model number you can find out what socket type the CPU fits into so then you may be able to find out what other CPUs will fit into the socket.
This doesn't mean that they will work because it also depends on whether the motherboard, chipset or BIOS will also support it.
If you find a better CPU that is compatible with the socket, then all you can do is try it and see
da
@aleksandra29103
Please Aleksandra , mail me the CPU & socket data you found i'dd like to upgrade mine
Ciao bart (Belgium) bart.koens@gmx.com
da
How about sticking Core i7-3632QM Ivy Bridge in it instead. It would be awesome if it was supported by bios. The Intel Core i5 2540M works too, its in me lappy.
Punteggio 0
Aggiungi la tua risposta
Aleksandra Hribernik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 53
Tutti i Tempi: 1,352
