Salta al contenuto principale
Apple's operating system for its Mac desktop and portable computers.
Procedure to change the default application
Microsoft Excel happens to be my default application, I need the procedure to change it from numbers. Please guide me.
Thank you
Narayanan Lakshmanan India
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Click on a spreadsheet document, goto the menu File then slide down to Get Info your files info pane should be open twist the twisty Open with: There you can alter the application to use in this case MS Excel to alter all spreadsheets click on the Change All button
Punteggio 0
2 Commenti:
I am unable to understand the twist the twisty Open with.I am unable proceed further.Please clarify.
Thank you Naryanan lakshmanan India
da
Click on the small triangle that's called a twisty as when you click on it more information is shown user that heading.
da
Preparati per le riparazioni future
Aggiungi la tua risposta
N LAKSHMANAN Chettiar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 81
