Salta al contenuto principale
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
How to replace the battery?
How to open the back cover and replace the battery?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @bamboo ,
To replace the battery you need to remove the LCD screen, as the battery is mounted on the back of the mid frame which is screwed into the back cover from the front.
Here’s a video that shows the teardown of the phone.
From about 2:30 minutes onwards in the video (after the screen has been removed), you will see how to get to the battery.
Punteggio 2
1 Commento:
Hi jayeff,
Many thanks for your advice.
Battery replaced and new one seems to be holding charge.
Regards,
bamboo
da
Preparati per le riparazioni future
Aggiungi la tua risposta
Stephen Abell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 46
Tutti i Tempi: 4,174
