Salta al contenuto principale
Mid 2014 / Intel Core i3 / 500GB Hard Drive
Screen showing multiple flickering circles on right side of screen
My screen is displaying flickering circles in the right side of the screen that draw the mouse pointer directly to them causing no functionality of the mouse. The memory is showing close to maximum; space available on the hard drive. Force “hard” restart sometimes clears up the flickering enough to log in a function for a random amount of time (range: 5 min - over 1 hour).
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hi @allenr89 ,
Try disabling the touchpad (use a USB mouse to navigate through the laptop) and check if the problem stops.
Here's how to do this
In the Control Panel, select Hardware and Sound. Select Devices and Printers. Select Mouse.
Select the Device Settings tab. Click Settings.
Select Tapping. Click the settings icon.
Uncheck "Double Tap to Enable or Disable Touch Pad".
If it works OK there may be a problem with the touchpad
Punteggio 0
1 Commento:
I have same problem but it's all over entire screen and it looks more to be a touchscreen issue. No prior screen damage or drops. Updated to latest drivers, updated Bios, rolled back to several older display drivers,The same time this started for me I also have a ⅓ of the keyboard that does not work. Mainly middle of keyboard. Replaced keyboard still no improvement.
da
Aggiungi la tua risposta
Rob Allen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 441
