Salta al contenuto principale
Il Samsung Galaxy S9 si identifica per il suo numero modello: SM-G960XU. Lanciato nel marzo 2018, rappresentano una generazione della serie Samsung Galaxy S. Disponibile in Lilac Purple, Midnight Black e Coral Blue.
Would I need to replace the LCD or the LCD with digitizer?
I have an s9 and I've dropped my phone which crashed. I tried turning on my phone and it only show the top half and the bottom half green screen flickering. I'm not sure which part of the phone I should get fix and I have little to no knowledge about this.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Samsung Displays are the more high tech on the market, OLED Display ,TouchScreen and Front glass come from factory in sandwich mode less than 2mm, replacing single parts such as OLED or Touch Screen requires expensive equipment, and in your case you have a bad OLED Display (The Expensive Part), so you have to replace the complete Screen sandwich.
SUMMARY: Replace OLED Screen Assembly, is DIY Project, Replace OLED Screen Assmebly with Frame/Housing.
Punteggio 0
1 Commento:
Yes, thank you and i know its really expensive part. I broke it recently and wasn't sure which part to get it fixed which I asked phone repair shop and they say around $260 and up.
da
Preparati per le riparazioni future
Acquista tutti
The LCD and the digitizer are basically fused together. You will need to replace both. If you are doing it yourself then good luck, the screen is glued on tight.
Punteggio 0
Aggiungi la tua risposta
kelly tran sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 680
