Salta al contenuto principale
Schwinn Mens Tourist 28"/700c Road Bike
How do I remove crank on bike
Ok so I found out my bike has a SR suntour crank and I tried looking up for a way to remove it and I got nothing so con one of y’all tell how to remove it please
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Here’s how to do it:
https://www.youtube.com/watch?v=baa0ghR5...
Punteggio 1
1 Commento:
@mayer its a bike crank not a freewheel
da
kevin remove the chain. Insert one 8-mm wrench into the Suntour crank on the drivetrain side of the cranks. Insert another at 180 degrees on the other side of the cranks. Use opposing force with the two wrenches to loosen the 8-mm hex screws on the cranks. from here
Punteggio 1
4 Commenti:
@oldturkey03 That’s what I tried doing but the space to slide the socket or the wrench in is too little
da
To little how? there are deep socket wrenches that have a handle on the side. Possible to use one of those? Any chance you can take a couple of pictures and post those with your QUESTION so that we can evaluate? Aggiungere immagini ad una domanda
da
You got Instagram so I can ft you
da
No. Sorry all I do is iFixit. No social media :-(
da
Aggiungi la tua risposta
kevin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 489
