Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
No camera functions working
So my colleague replaced the back cover and screen for an iPhone X. By replacing the back cover i mean that we bought a new frame with the back cover already in place. After the replacement the main camera no longer works and the front camera only works sometimes.
I have tried the following:
- Replaced the main camera.
- Replaced the front camera.
- Replaced the flash and on/off button cable.
- Replaced the bluetooth antenna cable.
- Checked all the connectors on the main board and all look fine.
- Did a full reset of the phone 2 times.
All this and nothing worked. I tried turning on the flashlight as well but nothing happened. Any idea what it could be and what to try next?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
I’ve seen this a couple times on an iPhone X, and it seems to be a board defect. When you say you tested the board connectors, did you test voltage on the pins specifically?
Punteggio 1
1 Commento:
Thank you for your answer.
So if it's a board defect it means my colleague didn't cause it and it was a coincidence? I mean it's not exactly easy to damage the board by removing it from the case. The iPhone X board don't really have a lot of exposed components.
Never said i testet the board, i just visually checked the connectors. Maybe i should have been more clear about what i meant. Whats the best way to test the voltage? Is there a tool i can use or a multimeter will do?
da
Parti e strumenti correlati
Acquista tutti
Try to put it back in the original back case and when it works you know it is a fault in back case that you bought.
Punteggio 0
1 Commento:
Already have. Same result unfortunately.
da
Aggiungi la tua risposta
Total Repairs AS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 86
