Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
Can you install a blank SSD if your old SSD has failed?
So my old SSD failed so I need to put a new one in.
I don’t care to have a backup, I just want to start new so can I put the new blank SSD in the system and download the OS over WiFi directly without an external hard drive?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Thanks for asking Luke! If you don’t need any data swapped then you should be able to install a new ssd into the device and use internet recovery to reinstall Mac OS by pressing the command key + R at the same time but keep in mind that these devices use a proprietary connector and it’s not a normal m.2 or sata connection.
Best regards
-Activoid
Punteggio 2
3 Commenti:
So I can just put the new one in then where the old one was right and it should work so I shouldn’t need any connections?
da
Yes, Refer to this guide on ifixit Sostituzione SSD su Macbook Pro 13" inizio 2015 con display Retina . But, remember the drive slot is proprietary.
da
Aggiungi la tua risposta
Luke James Langpap sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 210
