Salta al contenuto principale
ATX Mid Towers have the same general build and parts as other mid size computer towers
BIOS Stalls after loading date line
AMI BIOS stalls at the date line on a MSI motherboard. What’s the issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi Tom Zonsius
What model is the MSI mainboard?
If on POST Screen you can press on the Tab key to see more info.
Normally stalled / error hard disk, faulty drives connecting to the sata ports, etc can stall the detection.
I would suggest you to remove the sata drives one by one to eliminate or find the issues.
if all has been removed, but there is no improvement, consider clearing your cmos and see if it help.
one note you have to consider before clearing cmos is if you have bitlocker enabled.
clear will ask for recovery key.
go ahead if you have backup recovery key.
lastly is to update the bios
Punteggio 0
Aggiungi la tua risposta
Tom Zonsius sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 105
