Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
Device will charge not not boot
The device has all the power LEDs off, but when it plugs in only the charging light lights up. I’ve tried replacing the motherboard and the battery. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The motherboard to display cable was damaged.
Punteggio 1
Does your device have an hdmi port ? If so have you tried to attach it to a TV to see if your display electronics may be the issue?
Punteggio 0
1 Commento:
I found that it was the cable from the motherboard to the display was damaged.
da
Aggiungi la tua risposta
GanSolo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 196
